0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
I am new to forum and need some help please. I have just purchased a 1941 Chevy 1/2 ton truck and I am trying to find out what engine I have.
Here is the number stamped on the side of the engine Rt. side just behind the distributor. - N275940 CAL
VIN number on the Title - AD582461
Casting number - 8835497 17
The engine does not have an oil filter.
I would also like to know where can I find a Carburetor and water pump?
http://i1061.photobucket.com/albums/t461/waynesel1/download.jpg
http://i1061.photobucket.com/albums/t461/waynesel1/download-1.jpg
http://i1061.photobucket.com/albums/t461/waynesel1/download-2.jpg
Thanks in advance for your help.
Wayne Selway
Wayne Selway
Waynesel #850987 05/12/2012 5:12 PM
welcome to the garage Wayne - those numbers don't compute, neither appears factory, likely a CA DMV thing that may have happened decades ago when the engine was changed as the engine number would originally have been used for the title VIN .... a picture of the engine would get an ID from some of the gurus here, it would originally have been a 216, but may have been swapped for a 235, neither of which had oil filters
Flxible #850998 05/12/2012 5:49 PM
I don't know how to add pictures?
Wayne Selway
Waynesel #851001 05/12/2012 6:08 PM
Ex Hall Monitor
Ex Hall Monitor
Always glad to help. thumbs_up
Tiny #851003 05/12/2012 6:13 PM
Thank you that worked very well.
Wayne
Wayne Selway
Waynesel #851028 05/12/2012 8:40 PM
Ex Hall Monitor
Ex Hall Monitor
Looks like a 216 to me. Do your Town & Country horns work?
Tiny #851041 05/12/2012 9:31 PM
not yet
Wayne Selway
Waynesel #851079 05/13/2012 12:31 AM
3835497 would be a 1948-1951 216 block
AD was a 1941 Light Delivery (1/2 ton?) engine code prefix.
tclederman #851086 05/13/2012 12:43 AM
My local parts store has no problem getting a water pump.
What are you looking for with carbs?
My Blog
I have a Rochester currently but I do not know if that is the correct one for this truck?
Wayne Selway
Waynesel #851296 05/13/2012 8:06 PM
A Carter W1 would have come on a 41, but Chev sold Rochesters as a replacement.
My Blog
Thank you.
I guess I will look for a Carter W-1. I suspect they will be a bit hard to find and expensive?
Thanks Again
Wayne
Wayne Selway
Waynesel #851313 05/13/2012 9:39 PM
There are a lot of models of W1's. I do not know off the top of my head which one a 41 used, but they are not that scarce. Here's an ebay example
In checking I see 1941-42 used a mod #483 Part #839500
If you are not going for judging there are a number of models that will work.
My Blog
