1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Wayne - those numbers don't compute, neither appears factory, likely a CA DMV thing that may have happened decades ago when the engine was changed as the engine number would originally have been used for the title VIN .... a picture of the engine would get an ID from some of the gurus here, it would originally have been a 216, but may have been swapped for a 235, neither of which had oil filters
Bill | | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | I don't know how to add pictures?
Wayne Selway
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know how to add pictures? Always glad to help.
| | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | Thank you that worked very well.
Wayne
Wayne Selway
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Looks like a 216 to me. Do your Town & Country horns work?
Wayne Selway
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My local parts store has no problem getting a water pump. What are you looking for with carbs?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | I have a Rochester currently but I do not know if that is the correct one for this truck?
Wayne Selway
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A Carter W1 would have come on a 41, but Chev sold Rochesters as a replacement.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 38 | Thank you. I guess I will look for a Carter W-1. I suspect they will be a bit hard to find and expensive?
Thanks Again Wayne
Wayne Selway
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are a lot of models of W1's. I do not know off the top of my head which one a 41 used, but they are not that scarce. Here's an ebay example In checking I see 1941-42 used a mod #483 Part #839500 If you are not going for judging there are a number of models that will work.
