| | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | I pulled the ID tag from the rear on a frame that I have, which is from a ???? Just so happens the I bought an1950 chevy 3100 parts truck and this frame was under it. So I know the axle width is correct, but what do these numbers on the tag mean? Here is what it reads. CY-AS 4808 0888 V033A
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you can, posting some pix of the rearend might help give a starting point.
Bill Burmeister | | |
