| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Just completed rewiring 37 1/2 Ton.. Before conecting the wire to the sending unit when I turned on the ignition switch the guage went straight to full.... I understand this is correct..... I then thought that if I grounded out the wire which goes to the sender the guage would then go to empty? I ground out the wire on the negitive battery cable .... now the guage does not work | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The gage has to go to ground through the float resistor at the tank. My truck had a fried gage. I think I have fixed it but don't know yet. Still in the restoration phase. If you take the gage out there is a very fine wire wound in a coil. Mine was burnt off. I simply took one wrap off the coil and resoldered it to the terminal. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
