1 members (baldeagle),
107
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85105 09/25/2003 11:02 PM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Ok I am heading to the junkyard on sat to see if I can locate a HEI system for my 68 chevy. Is there a physical difference from my points distributor? I guess what I need to know is what exactly am I looking for?
Thanks in advance
Brad | | |
#85106 09/25/2003 11:37 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The distributor will be physically larger at the cap area. The coil is mounted in the top of the distributor cap and is covered by a plastic cover. Look for a distributor with newer plug wires on it as they are different than the points type wires(ends are different on the cap) Have you asked around locally to see if anyone has one laying on their bench or shelf?
#85107 09/25/2003 11:45 PM | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Ok will go shopping for one this weekend. Also I found a pic of one on the web. Will I need to pull the entire distributor with cap and all or just the top part? | | |
#85108 09/26/2003 1:05 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Skokie, You'll need the distributor, cap and sparkplug wires to match the cap. Not to confuse you but there is also an early version of the HEI that does not have the coil in the cap, still the cap is going to be about twice the diameter of the original. Have fun.
Regards, Larry 63 C20 daily driver
I don't own a vehicle that isn't old enough to drink. | | |
#85109 09/26/2003 3:48 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I assume you are using the HEI with a V-8. Most of the time there will be clearance problems with the firewall using the HEI. I ended up having to notch my firewall and I still had problems. The vac advance and wire connector section were about 180 deg apart and both were close to the firewall on each side. I solved that problem by rotating the cap 90 deg relative to the distributor body. That can be done by carefully measuring out and filing a new notch in the distributor body 90 deg (this is the notch that fixes the position of the cap. Now, the wire connector extension on the cap points forward and no more firewall clearance problems. When you are at the salvage yard, make sure you get the two-wire connector that connects to the distributor. Regular slide on connectors can be used but the special connector designed for that distributor works better. | | |
#85110 09/26/2003 3:51 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Forgot to mention you do NOT need the ballast resistor with an HEI. Wire the distributor straight to your ignition supply. You may also have a wire that goes from your starter to the points distributor. This wire isn't needed with the HEI. It was used to provide 12v directly to the points distributor during cranking for some added spark intensity. The ballast resistor drops the voltage to the distributor to 8 or 9 volts I think, probably to preserve point life. | | |
#85111 09/26/2003 3:55 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Also, get the wiring plug that snaps into the cap. It has the power wire connection. The wire that currently feeds your points won't be big enough, you'll need to replace it with 12 ga. wire plugged into the fused ignition on your fuse panel.
Fred 52 3600 69 C-10
#85112 09/28/2003 7:01 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I offer this opinion here even though many of you will not agree with it. You have a 12volt system, but the charging voltage will be around 14.0 volts. A stock resister wire is 1.4 or 1.8 ohms (if I remember correctly) depending on if it's for a 6 or V8. It will drop the voltage 1-2 volts. This will still give you 12 volts at the distributor and draw only slightly above 1 Amp. Get out your voltmeter, do the math and you'll see that this is correct. A popular misconception is that you have to use 10-12 gauge wire with a 20 amp fuse. Your stock dash radio uses more current than a HEI. It has a 5 Amp fuse and is wired with 16 gauge. Your resister wire is the cloth covered wire that goes from the distributor to the firewall bulkhead connector. Just crimp(it won't solder) a new connector on the end and plug it into the HEI. You'll both be very happy. When I first put the HEI in my 292, I bypassed the resister. The third time I started the truck, the HEI module burned out. I reconnected the stock ballast resister wire and it's worked just fine for years. The "nay" sayers will want to tell you that you won't get as hot a spark. Bunk! Nay sayers don't even say nay.
'67 GMC 3/4 292 4spd
#85113 09/28/2003 7:41 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | I say "nay"; but whatever works for you, Richard  . Skokie, I ran a switched, 12 volt fused supply from the fuse block and it was a 12 guage wire. The fatal mistake is the grease. That's right, the dielectric grease that's under the module? Without it, the module will overheat and fail . If it's been there awhile, clean it off and replace with fresh. If installing a new one, the grease packet is usually in the box. HEI is a good system, just has a short service life. Don't expect more than 50k miles without needing to replace something.......plugs, wires, coil, cap, rotor and sometimes module. They just burn out. Always check the advance mechanism....they are usually worn and rusty. Mr. Gasket sells a recurve kit that has all the parts you need to fix it. You don't have to install the aftermarket weights or springs, just the bushings; unless you are running a custom engine or gears out back........That's another subject!
*** GMC ***
#85114 09/29/2003 4:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Always check the advance mechanism....they are usually worn and rusty. And check the vacuum advance. When I bought my 69 the PO had slapped in a well-used hei. Milage was horrible, so I checked the vacuum advance, it didn't work. Bought a complete upgrade kit with hotter coil and performance module, advance module, springs & weights, cap & rotor. I also found the weights rusted in place, so I had been runniing only 6* advance at speed. Got 9 mpg on a road trip before the upgrade. Now I'm running 42* total advance, and am getting 14 mpg on the highway. As far as voltage to the hei, they were designed to run anywhere from 11 to 15 volts. I don't know what the output voltage change is within that range, but if your module burnt out it was either a bad module, the voltage regulator was set way to high, dielectric grease hadn't been used or a static field had been introduced to the module. It wouldn't have been the fault of standard voltage. I'm not saying that the module won't last longer on the reduced voltage, it probably will. But it does raise another issue, what will happen if the alternator dies and the voltage at the hei drops to 8 volts? Will the hei have enough spark to run the engine? How about running a test on that, Richard? I'd like to know the results. Also, have you connected a voltmeter to the hei output and compared the voltage differences? This, too, would be interesting to see.
#85115 09/29/2003 5:39 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | When GM started using HEI's around 1975, I had a failure in a new company truck.The rotor, cap and wires were all burned. The culprit was the spark plugs,the truck went 30,000 miles on the original plugs,the electrodes were almost complety eroded away,yet the truck still ran ok.After that, I always replaced the plugs sooner ,never experiencing another problem at all. The HEI produced so much voltage to fire the worn plugs,it destroyed the wires and cap. | | |
#85116 10/02/2003 6:53 AM | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | When I was dragracing my Pontiac, I tried all the tricks looking for more power. I wired in a cut out switch for the alternator so it wouldn't charge when racing. At the end of the track just turn it back on. It sound like a good idea till the HEI started to cut out. The battery voltage along wasn't enough to keep it running. It was a 11.0-1 compresson alcohol burning engine but, HEI needs the proper voltage. Thats why GM but 10 or 12 gauge wire to them. And you do need the wire from the starter or a from the start circut of the ignition key. With out it, it will never start. The ignition side (run) of the key switch does not send voltage to the coil in start mode. Just tie start and run together at the key switch and run a new 10 gauge wire out to the distributor. Shove the stock wires under the dash for the next guy to restore back to original. Joe | | |
#85117 10/02/2003 7:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If you tie the start and the run wires together you starter will not shut off
