6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#850962 05/12/2012 3:56 PM
I HAVE 1965 CHEV SHORTY,THE CHROME THAT RUNS ALONG THE SIDE OF TRUCK,IS IT REAL CHROME? IT IS ORIGINAL,,WHAT SHOULD I USE TO REMOVE MINOR SCRATCHES,,OR IS IT THERE FOR GOOD,,THANKS
It is silver-anodized aluminum, so you must remove the anodizing, in order to polish it. We use Easy-Off oven cleaner, followed by the buffing process. If the scratches are into the parent-material, you will need to use progressively finer grits of sandpaper, starting with 1200 up to 2000, followed by the buffing process.
sounds good,,thanks tony
