7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85090 11/27/2003 7:28 PM | Joined: Feb 2003 Posts: 21 Member | | Member Joined: Feb 2003 Posts: 21 | i have a reducer from one of the online parts stores.it is the light duty one. has bare wires on each end . i have two questions .1. when connecting it to my gas guage how do i prevent the bare wires from shorting to the body? 2. if the gas guage just measures resistance changes why do i need it at all? there have been so many posts about this i not sure just who to believe. could someone settle this once and for all
cliff 39 chevy suburban w/250-6cyl "Valve in head means ahead in value"
#85091 11/27/2003 9:54 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Cliff,
I bought my '49 pickup when I was an undergraduate electrical engineering student umpteen years ago. As a project for a measurements class, I setup a '49 fuel gauge and sender and then measured the current into it as a function of the voltage applied.
The system (gauge + sender) is designed to read correctly independent of the voltage applied to it. If it wasn't, then the gauge would be moving everytime you revved the engine and the generator voltage went up.
The only question then is how much voltage can be applied before it does burn out the coils. I can't remember the exact numbers from my test but the conclusion was that the system didn't draw enough power at 16 or 18 volts to even worry about.
The summer after that class, I rewired my '49 and converted to 12 volts. I ran 12 volts through the '49 gauge without problems for over 20 years. I did have one fuel gauge problem. The sender in the tank finally broke (mechanically) after 45 plus years and I had to replace it.
I've posted this here before and lots of folks have horror stories about how their gauge fried on 12v etc.. If you hook it up wrong, even at 6 volts, it'll cook in a heartbeat. That's why the divider between the terminals on the back of the gauge.
I'll have another look for the paper I wrote for the class, it has all the readings, graphs and conclusions on it.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#85092 11/27/2003 10:34 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I was curious about just what was the difference between the 6v and 12v gauges so I went out and did a little measuring just now.
Since the fuel sending unit is simply a resistor that varies between 0 and 30 ohms on Chevy's we'll assume that the sender is at the 0 ohm end and then we can figure the power (heat) generated in the gauge itself.
'38 truck fuel gauge - 30 ohms between the supply terminal and sender terminal
'64 Chevelle fuel gauge - 47 ohms between the supply terminal and sender terminal
Using Ohms law Power (watts) = (Voltage * Voltage)/resistance (ohms)
'38 gauge at 7 volts = ( 7 * 7)/30 = 1.63 Watts '38 gauge at 14 volts = (14 * 14)/30 = 6.5 Watts '64 gauge at 14 volts = (14 * 14)/47 = 4.17 Watts
That's the numbers. I ran my '49 without a dropping resistor and plan on doing my '38 the same.
#85093 11/28/2003 12:30 PM | Joined: Feb 2003 Posts: 21 Member | | Member Joined: Feb 2003 Posts: 21 | many thanks for all that useful info...
#85094 12/05/2003 3:51 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Cliff, Why not simply install a Runtz reducer? I'm sure you must have read about it after doing a search? I'd be happy to show you what they look like, assuming I can find my spare. Installion is pretty straight forward.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
