4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | Hi all…I have just pulled my 216 from my 1946 ¾ ton Pickup to replace all the gaskets…it had been leaking oil from various places and though it was time to replace them…after reading many, many threads here on the subject of oil leaks it seem that a vented PCV system will my solve my problem. There were many solutions here on all types of engines…235, 261, 292 and 283’s…but no 216 PCV conversions and be for I attempt to use one of the talked about conversion for these engines, I thought that I would ask the experts for help. I only want to do this once…
Any thoughts on a Oil Catch can system?
| | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Oil Catch can system
What is that? | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | You shouldn't count on curing the oil leaks with a PCV system. It is better for the engine and it will help keep blowby fumes contained. You would set it up the same way you would fro a 235. I have mine drawing from the converted vent tube and the air inlet is a filtered oil cap. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Old Stovebolts leak. At least, that's my experience. But, I keep driving and enjoying, and hope you do, too!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
