| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Need to get a new hinge for my 54 3100 glovebox door.has anyone seen this available McMastercarr has a double swaged that may work
....David
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Try posting a Parts Wanted Ad in the Swap Meet.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Been gathering parts from 3 different trucks & finally coming to the end of a frame off on my 51. I have 3 sets of glovebox hinges to fit 47 to 53, not sure if 54 hinges are the same? You would have to check this out. Anyhow if you don't succeed in finding something soon I would be happy to mail you the extra set I have that came from a 53 cab. Just cover the postage.
| | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | 54 hinges are completely different from the 47-53 since the glove box door is different. I can take a picture of mine and post it tomarrow if that will help. I'm trying to get pictures of my build as I go along anyway. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 |
....David
| | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | I took some pics of my glovebox hinge. I had to go by the local hardware supply today and saw some 2 1/2 inch continuous hinge material that would work. It had no holes and had 1/2 wide hinge spacing. If you could find the right size torsion spring you could even cut out a section and insert it.
My hinge was 11 1/8 long with the side that mounts to the dash 1 1/4 wide to the hinge pin and the part that mounts to the door 9/16 wide. Note that the holes on the dash side are slotted left to right and the holes on the door side slotted up and down to allow for door adjustment. The torsion springs just assist the door in opening.
I uploaded to photobucket but I am having trouble with their site right now and will add a link later.
Hope this helps Rick
| | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | | | |
