3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
V
V Offline
As I hear many others have experienced, I failed to take enough pictures of my engine tear down. It's been too long since I last touched the engine, so now I am at a loss and my shop manual doesn't mention anything.
I have two holes in the block that have no threads and I can't remember what they're for. I'm fairly new to this, so I'm sorry if I'm missing something very obvious.
The first is right next to the air breather. I checked and it's not for the beather's mounting clip. If I check it with a rod, it goes right to the cam. Here's a picture, it's the tiny hole next to to the air breather hole: http://i.imgur.com/5mhH2.jpg
The next hole I can't identify goes all the way to the other inside wall of the engine. It's the tiny hole in the bottom center of this picture, located directly beneath the air breather hole: http://i.imgur.com/yjeWC.jpg
I'm not sure if it helps, but after the rebuild of the engine, I found a part that I couldn't remember if I took it off the engine or not. It's this part right here: http://i.imgur.com/b0FMn.jpg Not sure if that is related or helps at all, but I have no idea what that piece went to. It doesn't look stock, as the threaded hole in the top right of the piece looks fairly home-made.
Any help would be great. I've tried talking to some local guys, but they all replaced their stovebolts with newer V8s and they don't have anything similar. I can't start hooking up the engine until I figure it out since they go right into the block.
What am I missing?
1957' Chevy Pickup
My welcome thread: Introduction and Story
My Album: 57' Chevy 3100 W/235
That part goes in the engine,and is held in with two screws.You'll have to take the pan off to install it. the plate you have is held in with two sheet metal screws thru thoes two holes it covers the breather so oil does'nt splash out.
Pete
Isn't it a baffle or deflector that mounts inside under the road draft tube?
Professional Novice
V
V Offline
Haha! So if I'm understanding you right, that plate does actually fill those two holes? Just from the inside?
I had a hunch, but again it's been a few years since I had the engine apart. That helps tremendously, thanks guys!
1957' Chevy Pickup
