7 members (TUTS 59, MNSmith, RLB, carbking, tclederman, Wayne67vert, 1 invisible), 120 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
#848759 05/04/2012 3:07 AM
I'm putting a serpentine belt set up on the 350 in my 55 2nd 2 ton. I am not putting power steering on the truck just yet. They make a by pass pulley for the A/C compressor but not the power steering pump. If I remove the pressure valve from the back of the pump and block off the outlet and return line will that work without blowing fluid everywhere? Or do I have to remove the pump vanes?
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
I've made a loop from the pressure fitting to the return nipple on the resevoir can to keep from running a pump with no fluid and it worked but don't know if this would be okay for driving.
Evan
You should be able to find a shorter belt at your FLAPS.
1954 GMC De Luxe COE
Ditto. I used a serpentine setup off a Camaro minus the smog pump. Found a shorter belt at Autozone & it works fine.
Robert C.
I'm a Genius in the making.
1950 3600
Thanks guys, I thought about a shorter belt but I'm going to use the pump eventually. I wanted to run it with the pump on and thought maybe someone else may have done that. I'll remove the pressure valve and see what happens then do a follow up post with the results. Thanks for the input! SEE YA! Mark
More pix on Flickr
