| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I'm putting a serpentine belt set up on the 350 in my 55 2nd 2 ton. I am not putting power steering on the truck just yet. They make a by pass pulley for the A/C compressor but not the power steering pump. If I remove the pressure valve from the back of the pump and block off the outlet and return line will that work without blowing fluid everywhere? Or do I have to remove the pump vanes? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I've made a loop from the pressure fitting to the return nipple on the resevoir can to keep from running a pump with no fluid and it worked but don't know if this would be okay for driving.
Evan
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You should be able to find a shorter belt at your FLAPS. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | You should be able to find a shorter belt at your FLAPS. Ditto. I used a serpentine setup off a Camaro minus the smog pump. Found a shorter belt at Autozone & it works fine.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks guys, I thought about a shorter belt but I'm going to use the pump eventually. I wanted to run it with the pump on and thought maybe someone else may have done that. I'll remove the pressure valve and see what happens then do a follow up post with the results. Thanks for the input! SEE YA! Mark | | |
