5 members (Jon G, Gdads51, 3B, NJC, 1 invisible), 102 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
I see all kinds of posts about swapping out the front suspension with newer front ends with disc brakes and power steering but..................
What about upgrading the rear drivetrain on a 64 c10 short stepper?
We changed out the front from a 76 GMC. Now it has 5 lug wheels, discs and power steering but the back half is still 6 lugs with 3 73 gears.
What options should I consider?
Thanks in advance.
ODSS Lawman
ODSS Lawman
With 3.73 gears, I'd let it be. If you go too tall your truck will be a slow turtle.
Provided you have a stock engine of course.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
You can have the axle flanges redrilled to the 5 lug pattern, then use drums from the later 5 lug truck. Alternatively, if you can get the rearend from the donor truck that the frontend came from, you can either use the entire rear by putting the mounts frm the original rearend on it, or you can get 5 lug axles by simply having the shafts from the donor truck cut down to match the originals, then grooved for the C lock. You will also have to use the side gears from the spider set, as the later axle is 30 spline vs the 17 spline of the '64. The parts will interchange.
Bill Burmeister
