8 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd, Forty9),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Can find Chevy VIN decoders, can not find GMC decoder. Please help with 11001HF1241A believed to be a 1964.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Try jolly's GMC site. Check the links section here for the URL. | | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks a lot, got it!! GMC, 64, shortbed, Oakland Ca, 1/2 T. They didn't have a code for Wide-side or Fender-side. I wanted to see if this truck was switched from one to the other.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2012 Posts: 13 New Guy | | New Guy Joined: Apr 2012 Posts: 13 | some (most?) cabs for fenderside trucks had a triangular "splash shield" at the rear corner. I closed up the gap between the cab corner and step. I dont think fleetsides had it. | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | 1 this is an "I" for chevy inline 6, {bait & switch engine} 10 = model 1000 01 = wheelbase, 115" short bed H = Plant code, Oakland CA F = series 1964-66 1241 = seiral number 241st off the line A = DOT GVW rating, Class 1 6000 lbs of less
