3 members (1955 1 Series, Gdads51, 1 invisible),
75
Mod | | | Forums66 Topics128,037 Posts1,055,582 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85002 03/19/2002 9:17 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i have a 93 g.m.c. i ton dually, 454, auto, loaded. horn, brakelights and 4 way flashers don't work. replaced brakelight switch, still no brakelights. power to both sides of fuse. any idea? oh yeah--got turns signals back up, and tail lights--everything else works | | |
#85003 03/20/2002 4:09 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | What do the horn, the four ways and the turn signals have in common? | | |
#85004 03/20/2002 7:30 AM | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 | Did you check or repalce the horn relay??
What about the hazzard flasher??
OR the Directional switch in the steering column??
Kelly 1951 Chevy 3100 1967 RS/SS Camaro
#85005 03/20/2002 10:33 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | kinda figure it's a ground thing--thing is i can't find any wiring diagrams in the book that matches this particular truck. did the horn relay thing---notta----i always did say grounds were harder than positive shorts.  | | |
#85006 03/20/2002 11:12 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Koolcar,all those items are common to the wiring harness that feeds down the steering column and plugs in somewhere under the dash.There also may be a problem in the directional switch,as that controls brake lights, turn and 4 ways. | | |
#85007 03/24/2002 6:48 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Have you found the problem yet?
Saw a problem similar to this on a Dodge truck. The wiring ran on the bottom side of the column inside the plastic cover. There was a electrical connector about 6" below the wheel which made it nice to work on if you had to pull the column apart. The harness had been put in without enought slack. The tilt-wheel had been moved all the way to the top and the connector simply unplugged itself.
'67 GMC 3/4 292 4spd
#85008 03/24/2002 11:34 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Dave, don't you just "love" the new wiring diagrams GM puts out? They are worthless and very hard to follow. They only show one circuit at a time and not whole schematic like old ones. Don't show connector plugs anymore either.
Did you check the Bulbs? maybe messing with stuff blew them or? The tailight housings are plastic and bolt in from bed side, and require a seperate ground wire be attached, check that for rust.
Got that truck ready to pick-up yet? Sure been crappy lately, BUT, was nice yesterday! Huh?? :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#85009 03/25/2002 3:18 AM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | most folks have told me the turn signal switch is bad. bought one today. got the horn to work by knocking the sh@t out of it. the truck is an ex n.h.r.a. crash rescue truck--not much need for a horn since it was new. everyone tells me this is a real nasty job--gotaa take the harness apart, not looking forward to it. gary, ain't got to the truck yet---remember i lived in texas, and chilly to you is freezing to me--got it on my "to do" list. will let u know.  | | |
#85010 04/08/2002 11:37 PM | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | This is an easy one, truck is too darn new, too many wires. get an older truck and life will be good.
"So many trucks, so little time!"
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | |
#85011 04/09/2002 6:20 AM | | Anonymous Unregistered | | Anonymous Unregistered | Just a thought..... did GMC still use + ground in '93 ?? | | |
#85012 04/10/2002 4:32 AM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | DON'T KNOW ABOUT THE POS GROUND---AND I AIN'T GONNA FIGURE IT OUT FROM P O S WIRING MANUALS! AS FAR AS THE TRUCK BEING TOO NEW-----------I COULDN'T AGREE MORE. GIVE ME THE OLD HELD ON WITH A HOSE CLAMP SIGNAL-STAT SWITCH AND DIMMER ON THE FLOOR ANYTIME!!  | | |
#85013 04/28/2002 7:48 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If you have a tilt wheel, it will be more of a pain,but not too bad if you can borrow the correct tools to do the job and give it a little patience. . . . The department of Insurance and the department of motor vehicles made a study and a new ruling,,,,All new vehicles have to have a floor mounted dimmer switch and all the vehicles with the dimmer switch mounted on the steering column are required to have them removed and retro-fitted to a floor mount dimmer switch. During the study they discovered that 80% of all accidents were caused by Blondes getting their foot caught in the steering wheel when operating the dimmer switch.
