4 members (Donf, msmall, 2 invisible), 120 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Going to replace the clutch assembly on my 46 216 1/2t. It has the TT attached to a 4 speed. Once I draw the ball cover off and slide it back, does the pilot shaft slide out of the yoke so I can move the TT out of the way? Or do I have to unbolt the covers off the trundle bearings and separate the u joint? It is not really clear in my shop manual.
Rick...
3B Offline
Hy elmer46, yes on the trucks that the torque tube goes right up to the tranny, you have to disassemble the "U" joint to move the torque tube out of the way, hope that helps.
Put a bottle jack under the tube so that you relieve the pressure on the ujoint. Take the joint apart, and you should be able to slide the yoke back and then lower the tube.
Kurt
...support tube...
...remove ball cover...
...bend tabs, remove bolts...
...pic...
...pic...
Remove the crossmember first. In the video link above you see I missed that step.
Thanks all for the advise and the pics especially. Will look at the video soon too.
Rick....
great photos. helps a lot!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
