9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | That one has never had a filter installed. The small fitting is for the oil pressure gauge connection. If the dowel pin near the oil pan rail was pushed in, the block would be set up for a full flow filter with large pipe fittings. Since both the large and small diameter return ports near the oil pan are plugged, the engine was never equipped with a filter. You'll need to decide whether you want a bypass filter or a full flow, and plumb the block accordingly. Bypass filters do a better job of straining small particles out of the oil so the ideal situation would have both types of filter. Jerry
| | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thank Jerry. What's required to run both filters? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My 2 cents, is now's the time to get that plug pushed in (not always an easy task) for full filtered oiling. I had a difficult time when I did mine and so left it out as is yours, should have drilled it out or what ever it takes. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | What's required to run both filters? Obviously, you'll need two filter canisters. One would need to be the regular style bypass filter with a small-diameter orfice to restrict the oil flow through it, plumbed with the small flex lines we're accustomed to seeing. That filter housing should contain a very fine-media element capable of straining out microscopic particles of dirt. The Frantz-type filter that uses a roll of toilet paper would be a good choice for that one. The full-flow filter is plumbed with large-diameter lines, 1/2" NPT, I believe, and carries the vast majority of the oil pump output through the filter on its way to the bearings. This one has to be open-weave enough to pass sufficient volume to give the engine the luubrication it needs. For convenience, I'd choose a spin-on filter for this application. Basically, a full flow filter is there to strain out the big chunks that could damage bearings, score the crankshaft, etc. Most of the old Cummins and Detroit engines I used to work on had dual filters, one full-flow and another one a bypass type. Of course, some of them had an oil change interval of 10,000 miles or longer, and on the ones with the Frantz system we just changed filter elements every 10 or 20K miles, topped off the oil level, and never changed the main crankcase oil. It was still testing good on a spectrometric analysis after over 100,000 miles. Jerry
