1 members (dt235sd),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | I have a 58 3600. I want to remove the back break drum to check the brakes and bearing. However there is a large cone sticking out from the outside of the drum with about 8 bolts. Di have to take this off to remove the drum (looks like it). Then will the drum come off after that? Is there anything I need to lookout for Thanks Rick
Rick 58 3600 4 on the floor
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | To check the bearings you will need to remove these bolts to expose the heavy duty bearings.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Do I have to remove that to get the brake drum off
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There should be two slotted screws in the drum face. Thsoe need to be removed to take the drum off without disturbing the bearings. To check the bearings, the axle shaft needs to be removed, followed by the locknut, lock, and adjustmer nut. The axle comes out by taking the 8 bolts out, then sliding the axle out of the housing. You may need to tap the axle flange lightly with either a deadblow or brass hammer to get it to pop free. The bearing lock and adjuster nuts do require a special socket to remove them. This socket is readily available at any parts store. It has 6 pins on it, and is similar to the Dana 44 4x4 axle socket. Here's the page from the shop manual that shows how they come apart. The socket needed is tool #2 on this page. The currently available tool is only the socket part, and does not have the T handle. It uses a standar 1/2" square drive instead.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rickyt, once the wheels are off clean the wheel mounting surface of the brake drum, you should find two or three slotted head screws, those screws are holding the drum to the hub. Before you remove the screws and attempt to remove the brake drum, back the brake shoe adjustment off as much as you can, good luck, I hope that helps. | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi, Thanks this is all good info. Thanks you but how do I back off the brake shoe adjustment. Where would I find this adjustment Rick
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Figure 17 shown on this page shows the location in the backing plate of the access hole. The pic shown is for the front, but the rear will be the same. It may have a rubber plug that needs removed to access it.
