8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Hi guys, I have a 1983 pontiac firebird rearend under my '57.I went under tonight to do a brake adjustment,( pedal is a little low), there is no slot in the backing plate to adjust the brakes. What gives? Are these the type of brakes that you adjust while driving backwards and pumping the pedal? Thank you in advance for any input. Roy | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Your brakes should be self adjusting without the need to back up. Take a look at this kit: http://www.autozone.com/autozone/pa...8kolj?itemIdentifier=210302_0_11000_4231 The two silver pieces go together and the gear on the larger piece is turned by the gold colored lever when it is permitted to move enough as brakes are applied. Maybe you have some worn parts. these kits are $14 (U.S.) per side to replace. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The backing plates may have to have the plugs taken out. If you clean things up you will see the outline of the hole scored into the metal. Use a punch and knock it out, then get a rubber plug to put in the hole when your done. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Some have a slot or knockout in the drum. They are self adjusting & are suposed to click them up when you stop in reverse, but often The adjusters are not working or the adjustment screw in rusted tight. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Adjusting your brakes manually will give you a temporary fix. Your rear end is designed to be self-adjusting. Take a look here: http://auto.howstuffworks.com/auto-parts/brakes/brake-types/drum-brake2.htm to see the basic functioning of the self adjustment mechanism. IMO, I'd opt for the cure and not the band aide. Done once and you're GTG. Added: Some self adjusters rotate when the emergency brake is set. If you haven't been setting the ebrake, it's possible that could be the issue.
