3 members (j05h79, Phak1, Jay R), 73 guests, and 3 robots.
Topics128,154
Posts1,056,837
Members48,456
#849683 05/08/2012 5:02 AM
Just rebuilt all of the wheels on my 47 chev. The master cyclider had already been replaced but not filled. Power bled the brakes but still have to pump pedal once to get it to go firm. Is there still air in the system causing the pedal to be pumped once to bring it up?
If you have original routing of brake lines, the bleeding order is left rear, left front, right rear, right front.
I looks like you still have air in your system.
The master should have been bench bled before installation. Now there are going to be people saying it isn't necessary but, obviously, yes it is.
If the brakes are not adjusted up properly they will produce this symptom. With air in the system the pedal will give a springy feeling when you pump it up.
1951 1 Ton Completed
Riding in the Passing Lane
I agree with Nix. The huck brakes are tricky to adjust. There are 2 adjustments on each wheel. Tighten eachb adjustment till you get a heavy drag. Then back it of about 4 notches. When these brakes are right the pedal just barely goes down. You just apply pressure to it.
1972 Chevy c10 Cheyenne Super
This master cylinder was not bench bled. It was already in the truck when we got it. Can that be bled in the truck?
Thanks for all the suggestions guys! I re-adjusted the manual clearance and the pedal came right up!
