5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
…pic…
The sleeve looks like when installed will only come up to the groove - Is this the right one? Do I install it only part of the way down?
Thanks - Mark
You just want it to clear the end of the shaft. There is no reason to drive it all the way down.
1951 1 Ton Completed
Center the sleeve up on the worn groove and break the lip off. Do a good polish job on the damper hub with emery cloth before installing the sleeve and use red LocTite to help hold the sleeve in place.
Thanks gents - gonna degrease, pressure wash, polish and then install with LocTite.
