0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
…pic…
The sleeve looks like when installed will only come up to the groove - Is this the right one? Do I install it only part of the way down?
Thanks - Mark
You just want it to clear the end of the shaft. There is no reason to drive it all the way down.
1951 1 Ton Completed
Center the sleeve up on the worn groove and break the lip off. Do a good polish job on the damper hub with emery cloth before installing the sleeve and use red LocTite to help hold the sleeve in place.
Thanks gents - gonna degrease, pressure wash, polish and then install with LocTite.
