2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
I have a brand new galvanized gas tank that is going under my '69 C20 Panel. Should I paint it? If so, with what? Thanks for any info!
Best wishes,
Les
I don't know should you?
Here's what google chose to share
Painting galvanixed steel
Give me ambiguity
or give me something else
I wouldn't paint a new galvanized tank, unless you are going for a special look (and people are crawling under your truck!)
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
painting galvanized steel requires "damaging" the coating enough that paint will stick - for a while ..... why replace the best kind of factory coating with a home paint job?? if you decide to do it, vinegar will neutralize the zinc so it can rust like the rest of the truck grin
Would "look" good bare, for awhile. But after cleaning the oils off with thinner a coat of 3M's 8882 would help protect it from scratches from road rocks....... just my 2 cents
....David
