0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
My original radiator in the '55 second GMC with a 270 was ruined. It was a Harrison built in Nov. '55. I was given a 48 GMC 300 with a 270 and the radiator is fine. The 48 bolted right in and the two main differences are that the bottom hose "collar" is a sweeping 90 rather than straight, and the core is 1/2" taller. The overall dimensions of both are identical. Is there a problem running the '48 in the '55?
"Upon the plains of hesitation bleach the bones of countless millions, who when on the dawn of victory paused to rest, and there resting died." - John Dreschmer
If you can fit it in and hook it up it should work.
Gene
1959 Apache
the earlier one might not take as much pressure as the later one, which should have a 7# cap
thanks for the input
