| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I have a 12 volt installed in my 46. When I shut off the radio, I loose the preset stations. The company that installed it says I need another converter for the memory of the radio. Help
b51r
b51r
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the brand and model of the radio? Did the radio come with wiring instructions?
Most likely the memory draws very little current. There must be one connection to the radio for On/Off-power; and, another connection to the radio-memory that must be 12v all the time (to maintain the memory).
Is your 6v-to-12v converter switched-on by your ignition switch; or, is the converter always "on"?
| | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | It is a Kenwood. The company installed and I do not have the wiring diagram. The radio was originally wired direct to battery,but was causing a short and draining battery. Had some work done mechanically and he wired it to ignition switch
b51r
b51r
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello, You need a Link: Memory Maintenance Module to hold memory of the clock and station presets when you shut off the ignition switch. UPDATE:Go to this Post for new info ("Install Tips 12 volt CD/Radio in a 6 volt vehicle") Try here Tech support. Custom Autosound. They sell them on this page. Thanks | | |
