1 members (Steelonsteel), 125 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#849494 05/07/2012 5:00 PM
I have a 12 volt installed in my 46. When I shut off the radio, I loose the preset stations. The company that installed it says I need another converter for the memory of the radio. Help
b51r
b51r
b51r #849499 05/07/2012 5:10 PM
What is the brand and model of the radio?
Did the radio come with wiring instructions?
Most likely the memory draws very little current. There must be one connection to the radio for On/Off-power; and, another connection to the radio-memory that must be 12v all the time (to maintain the memory).
Is your 6v-to-12v converter switched-on by your ignition switch; or, is the converter always "on"?
It is a Kenwood. The company installed and I do not have the wiring diagram. The radio was originally wired direct to battery,but was causing a short and draining battery. Had some work done mechanically and he wired it to ignition switch
b51r
b51r
b51r #851385 05/14/2012 4:21 AM
Hello,
You need a Link: Memory Maintenance Module
to hold memory of the clock and station presets when you shut off the ignition switch. UPDATE:Go to this Post for new info ("Install Tips 12 volt CD/Radio in a 6 volt vehicle")
Try here Tech support. Custom Autosound. They sell them on this page.
Moderated by  truckernix
