9 members (Gib70, Gdads51, 78buckshot, Phak1, mo2cyl, Oldcaliforniakid, BC59, Wally / Montana, MickeyP),
81
Mod | | | Forums66 Topics128,049 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, does anyone have a wiring diagram or instructions on how to wire 1941 Fog Lights (see picture link) on a 46 Chevy Truck 6 volt with original Delco Remy switch? My Fog Lights
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Nice lights! If you pick up your power from the back of the ammeter, it will show discharge when they are on, just like the headlights, I like that. Put an inline fuse in this wire, and attatch it to the hot side of your switch. If you have an original switch, it may incorporate a fuse already. From the switched side of the switch, run the wire out to the lights, and spilt the lead, to power both lights. The lights will be grounded by the connection to the bumper bracket, so make sure they have good paint free contact there. That's how I did it on my '50. Here's the factory info from '51. They have a place for a jumper wire running to the tail light terminal on the head light switch. I suppose that's so when its foggy, you only have to turn on the fog lights, and the tail lights come on automatically, that way you don't have to remember to turn on the park lights. http://chevy.oldcarmanualproject.com/accessories/1951am/51aim48.htm | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I agree with Mr. Lang, and those lights are very DECO! Show a pic after the installation!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | What size wire do I need? 10, 14, 16 gauge?
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Without running the numbers, I'd say 14 would be just fine, if even a bit of overkill. 10 is extreme overkill. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe I would put a relay in the circuit. You could run 16-18 gauge wire from the switch to the relay & 12 gauge from the bat or junction to the relay & from the relay to the lights. You can use a 6 volt horn relay. 6 volt systems require heavier gauge wire.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 |
