3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#847500 04/29/2012 6:09 AM
Hello, does anyone have a wiring diagram or instructions on how to wire 1941 Fog Lights (see picture link) on a 46 Chevy Truck 6 volt with original Delco Remy switch?
My Fog Lights
1946 Chevy Truck Export Blue with Black Trim
Nice lights!
If you pick up your power from the back of the ammeter, it will show discharge when they are on, just like the headlights, I like that. Put an inline fuse in this wire, and attatch it to the hot side of your switch. If you have an original switch, it may incorporate a fuse already. From the switched side of the switch, run the wire out to the lights, and spilt the lead, to power both lights. The lights will be grounded by the connection to the bumper bracket, so make sure they have good paint free contact there. That's how I did it on my '50.
Here's the factory info from '51. They have a place for a jumper wire running to the tail light terminal on the head light switch. I suppose that's so when its foggy, you only have to turn on the fog lights, and the tail lights come on automatically, that way you don't have to remember to turn on the park lights.
http://chevy.oldcarmanualproject.com/accessories/1951am/51aim48.htm
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I agree with Mr. Lang, and those lights are very DECO! Show a pic after the installation!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
What size wire do I need? 10, 14, 16 gauge?
Bump
Without running the numbers, I'd say 14 would be just fine, if even a bit of overkill. 10 is extreme overkill.
1954 GMC De Luxe COE
Riding in the Passing Lane
I believe I would put a relay in the circuit. You could run 16-18 gauge wire from the switch to the relay & 12 gauge from the bat or junction to the relay & from the relay to the lights. You can use a 6 volt horn relay. 6 volt systems require heavier gauge wire.
1972 Chevy c10 Cheyenne Super
Thank you.
