Hi.
Started up the old truck first time after winter. Dripping oil from oiltube, the upper one that comes from the oil filter. I have an external one. seems like the oil gauge is connected also to the same spot where the tube enters the engine block. I have wiped it off, and it's hard to see where it leaks.
Thinking maybe it's just the tube being dry. Can't see that it's leaking where the oil gauge tube enters, and not in the the tube fitting in the block either. STILL it's dripping. Any good idea anyone ?
http://i185.photobucket.com/albums/x264/uffeg/2012-05-01141101.jpgIt leaks from the upper one, not the front lower one. And the filter is dry all around.
