3 members (Peggy M, Hotrod Lincoln, carbking), 43 guests, and 9 robots.
Topics128,014
Posts1,055,325
Members48,419
#848943 05/04/2012 11:53 PM
I was wondering if anyone knows if a 700r4 and small block bolted together can be installed as one unit without removing the grill and radiator.
thanks Brett
I've done it on a '64 twice, two different trucks. Love me some overdrives.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I would remove the radiator. Its only a couple of bolts and you already have it drained plus one little bump and youve ruined a 400 dollar peice. they are kinda fragile.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
Thanks guys, I thought it would work. Should make it a lot easier to install both at once.
have you removed the crossmember that ran under where the bellhousing use to be?
ron
Just getting things figured out. Did"nt know I had to remove the crossmember, thank you padresag.
you are not going to get it in there otherwise unless you manipulate the floorboards severely, you will then need to install a rear trans crossmember. if you could find a powerglide rear crossmember from those years it would make it handy for you, there are other options though.
http://www.persh.org/pickup/700R4.htm
ron
you may also have to do a little work on that seem that comes down under the firewall -on top of the bellhousing area for clearance. If all of your cab mounts are in good shape(not collapsed or any rust problems in that area) you may get away with not having to do that little modification' one thing always leads to another
