3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#848897 05/04/2012 7:46 PM
Hey; Does anyone out there know if there is an open pumpkin that will bolt into a 51 chevy rear axle banjo( 1/2 ton 10 bolt) and use the same axle shafts that are in the 51? If that won't work, what can I use to convert the rearend to an open driveline and hook up to sm420 4 speed? Thanks for your help Dave
oldburbs #848906 05/04/2012 8:37 PM
Riding in the Passing Lane
The 55-62 pumpkins will fit.
1972 Chevy c10 Cheyenne Super
oldburbs #848907 05/04/2012 8:41 PM
You can also change out the rear cover and yoke of the SM420 so that it will work with the enclosed driveshaft....
Kurt
can I use my axle shafts that are in the rearend?
oldburbs #848948 05/05/2012 12:39 AM
Yes,you can use your original axles with wrenchbenders recommendation.You will also have to set the pinion angle and weld up the pivot points on the torque tube rear end on both sides.Here is a picture of the pivot points I welded up on mine. pivot points
I put a t-5 in mine and really enjoy driving it.
Good luck,Tim
1951 3100 Chevrolet
