8 members (51sub, 55shaker, Hotrod Lincoln, mason86, Paul Mullen, Peggy M, walter74, Bill Hanlon),
78
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | Anybody have an opinion on the best paint gun for the money ? I have been doing decent paint work with a cheap starter type gun but it's time to move on to a better more professional quality gun. My dad has an old Binks conventional he wants me to have but I like the idea of the gravity feed, low pressure guns that use half the amount of paint. Any advice?? Thanks in advance. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Both SATA and DeVilbis make great guns,have both and I have been spraying for 20+ years. If I were to get a new gun today and had a budget of a couple hundred bucks, this is the gun I would get. Look at the bottom of the page - the DeKups are something alot of shops are switching to as you can switch between colors and clearcoats quickly. but most of all the gun cleanup is quick and less costly as you use a bunch less thinner. As well you can store un used paint for a few days in the cups. This is similar to the gun we ar using now
....David
| | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | Thanks. Went with the Devilbiss. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks. Went with the Devilbiss. Which one did you get? | | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | | | |
