| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84880 02/27/2002 4:01 PM | Joined: Feb 2002 Posts: 3 Junior Member | | Junior Member Joined: Feb 2002 Posts: 3 | Just purchased 1959 chev apache and someone has changed the starter for one with solinoid and has somewhat butchered the wiring. Question.. Has the 59 got the ballast resistor or a resistance wire. Kayken | | |
#84881 02/27/2002 6:02 PM | Joined: Oct 2001 Posts: 1 Junior Member | | Junior Member Joined: Oct 2001 Posts: 1 | It should have a ballast resistor on the firewall.Resistance wire going to the positive on the coil. | | |
#84882 02/27/2002 7:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Unless you have an aftermarket coil with an internal resistor.
Fred 52 3600 69 C-10
#84883 02/28/2002 3:59 PM | Joined: Feb 2002 Posts: 3 Junior Member | | Junior Member Joined: Feb 2002 Posts: 3 | Thanks.. Found the cut wires, put in a ballast resistor, found the cut off wire going to the solinoid and spliced it too hook up the bypass. Now sstarts and runs like a top
Thanks a lot. Kayken | | |
