1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
#84880 02/27/2002 4:01 PM
Junior Member
Junior Member
Just purchased 1959 chev apache and someone has changed the starter for one with solinoid and has somewhat butchered the wiring. Question.. Has the 59 got the ballast resistor or a resistance wire.
Kayken
#84881 02/27/2002 6:02 PM
Junior Member
Junior Member
It should have a ballast resistor on the firewall.Resistance wire going to the positive on the coil.
#84882 02/27/2002 7:58 PM
Unless you have an aftermarket coil with an internal resistor.
Fred
52 3600
69 C-10
#84883 02/28/2002 3:59 PM
Junior Member
Junior Member
Thanks.. Found the cut wires, put in a ballast resistor, found the cut off wire going to the solinoid and spliced it too hook up the bypass.
Now sstarts and runs like a top
Thanks a lot.
Kayken
