| | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I have installed a 1984 subaru gas tank were the spare tire used to be on my 54 panel, fit's great.I know the sending unit is working ,but the gauge itself won't,i can get the gauge to filcker a little if i give it full ground but that's it.I have tryed a universal gauge and that works fine,it has a hot a ground and a sending unit wire, the 54 gauge has only two contacts.Having a bit of trouble understanding it all. I have tryed two 54 gauges that i know were good when last used and get the same result.
Should there be any continuity between the gauge and the housing that holds it? Help !!! Len
layback
| | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | The ohms ratings are most likely different between the '54 and your donor. Go to an aftermarket site and find out how many ohms the stock sending unit has then measure the ohms on the Subaru unit. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 12v or 6v electrical system?
original tank sender (adapted to work in your tank) or later 12v Suburu sender?
If 12v system and Suburu sender and original 6v gauge, you might have a gauge-voltage problem (a runtz-style resister is recommended by many people), and the ohms-rating of the sender does not match the that needed/expected by the gauge (as posted by 5wests).
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | 12 volt system, 12 volt suburu sender and i assume the gauge is 6 volt. Yes i have the runtz resister on there 12 to 6 volts at the gauge, and sorry i forgot to mention that.
Thanks Len
layback
