| | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | anyone know how to remove axle shaft so i can replace inner seal? | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Does this axle have the nut on the end? My 29 and 30 ,have them . If so you need to remove the cotter key and nut, then remove the brake drum ,ussually with a puller, then unbolt the axle bearing,then pull the axle. | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | i've removed drum and the outer seal and bearing retainer, according to shop manual you just pull axle, don't know if there is a pin in diff. that needs to come out first or not. sometimes these trucks can be so simple to work on it's confusing, gonna try and rig an axle puller. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I do hope you open up the differential and see if you have a pin or clip before you use an axle puller.
Kurt | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | i looked ,i don't see any pins or clips, i was hopeing someone that had already done this would chime in before i go to far, don't know if the bearings need to come out in order to replace inner seal,if so that's another question on the best way to remove them.
