5 members (Otto Skorzeny, Erniegp, Hanks custodian, 2 invisible), 49 guests, and 2 robots.
Topics128,054
Posts1,055,780
#848259 05/01/2012 11:33 PM
1 Offline
Decided to upgrade my stock 1950 1/2T brake system, i've ordered the kit from CPP and am keeping my 6 lug pattern. I have a couple questions; Are my 16" stock rims going to fit? What happens to the emergency brake cable? The salesman mentioned I would have to modify a crossmember due to the 3 speed tran. Is this difficult?
I'm most of the way through my upgrade to a Canadian-built 1/2 ton pickup with the 3 speed using the CPP kit.
First of all, I'm doing brakes, tapered roller bearings, and a dual master cylinder upgrade (not power-assisted). So far, things have bolted together well, and I've just been collecting a few misc. parts to finish things off. If you're doing the dual master cylinder as well, you'll need a 9/16-18 inverted flare to 7/16-24 inverted flare adapter to connect the 1/4" rear brake line to the proportioning valve - I used NAPA's part # BK 6413309. While I'm at it, I'm replacing all the lines, as well as the rear wheel cylinders.
My stock wheels did not clear the callipers, so I'm going to need to go with something new. I'm leaning towards Wheelsmith's "Vintage" 16x6's, and I'll probably go with Michelin 215/85 x 16s or 225/75 x 16s.
Haven't any issues with the emergency brake cable.
I've got a few pages on my blog outlining what I've done so far, if that helps.
Cheers,
Fraser
1950 Chevrolet 1300 1/2 ton (Built in Oshawa)
http://1950Chevy.blogspot.com
back yard wrench turner
I just did the conversion. I have a '51 axle under my '38. I also stayed with 6 lugs. I had the back of my hubs turned so they run true. I used '79 K10 rotors and '79 C10 calipers. I also upgraded to a 1 inch bore master cylinder without power boost.
My wheels are original 17 inch and there are no clearance issues. The emergency brake works the same but I had to make a new mount for the handle since i changed motor and tranny.
Difficulty is dependent on your ability to make the parts that can't be bought.
You can see photos of this on my photobucket.
Good luck!
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
1 Offline
The package from CPP just arrived, and it is mostly apparent my stock wheels are not going to work. They do warn you though that may be the case on 47-50 trucks. Thats an added expense/decision I wasnt counting on, and am not sure I am ready to make...I have new 16"x6.5" bias plys and probably want a rim I can use those on, since they are new. What to do
On my '54 GMC with the CPP kit I just had to grind a dab off the 16" wheels to get them to fit.
http://www.jbhardin-gallery.com/trucks/wheeltrim.jpg
I have a few pics in this Folder you can look at. 1950, manual master cylinder.
Its a P.O.L. kit.
Most kits do not come with very good instructions.
I installed all new brake lines also.
