1 members (Hush),
121
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 11 New Guy | | New Guy Joined: Feb 2012 Posts: 11 | Hey everyone, I need help removing an ignition cylinder from my 1961 Chevrolet Apache 10. I cannot get the ignition cylinder nut off all the way without the bezel of the ignition cylinder stopping it. How do I get it off without damaging the cylinder? I'd like to get the 4 digit code off of it and get it re-keyed, if possible. Worst case scenario, I will replace it, but I'll still need to get the old one out. Any help is greatly appreciated! Thanks!
-Josh | | | | | Joined: Jul 2011 Posts: 15 New Guy | | New Guy Joined: Jul 2011 Posts: 15 | There is a hole in the face of the cylinder, stick a paper-clip in the hole & press down. You will feel a spring, with the key inserted turn the cylinder anti-clockwise & pull out. Larry | | | | | Joined: Feb 2012 Posts: 11 New Guy | | New Guy Joined: Feb 2012 Posts: 11 | Well, I don't have the key. I can turn it from off to run to start and use it normally, but I don't have a key. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | I think you have to turn it to "acc" to put a paper clip in the hole and that would be hard to do without the key, maybe Tony will chime in on this, he is full of all kinds of neat tricks, Now Tony get out of Dagwoods and help this guy out LOL
You Learn more Listening than Talking
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I think you have to turn it to "acc" .... A previous post discussed this and the "ACC" position wasn't available on stock trucks untill 1967  | | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | I had to carefully grind the ears off to remove the nut. I didn't have a key for mine either. | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | My 64 has an "ACC" position- Safe to assume it was replaced at some point in time? or was the option avaialable in 64? | | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | I have several trucks with the acc position. I believe spare parts is correct on turning it that way with the paper clip in. If you can turn it you may be able to remove it with that trick. If not remove the door lock cylinder and take it in to the lock smith and have a key cut for it and hopefully it hasnt been changed and is the same as the ignition.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
