| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84816 09/23/2006 12:53 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Two posts in same night on dash board stuff..you guessed it, I am in the process of wiring up my 46 1/2 ton.
I purchased a Jim Carter's harness. Included in the harness is the wire that runs from the ignition switch to the coil. The original setup has it installed inside the armored housing. I took the ignition switch apart and the got as far as the switch mechanism. Does the mechanism pop right out or is there a trick to installing a new wire inside the armored housing? I don't want to destroy the inside of the ignition switch if I can help it...
Long question short...how do I put a new hot lead in my ignition switch without destroying it?
Thanks in advance | | |
#84817 09/26/2006 5:08 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I havent been into the switch on mine (YET!!!) so I am not much help.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#84818 09/27/2006 3:31 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Thanks Toyvo, I'm heading out of town on biz...when I get back, I guess I will just take the plunge and mess with it a little more...if I mess it up, I guess i buy a new one and not worry a bit...  | | |
#84819 10/04/2006 9:43 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | OK, here is what holds an ignition switch on a 46 together; there are little indentations on the switch that hold the plastic inside the switch. I pushed out the indents with a screw driver and the guts of the switch came out. The original wire is held into place with solder and crimping as well as a crimp to hold the wire in place without placing any stress on the the connection. I soldered a new wire on and put it back together. Now I need to bench test it to make sure it is all working right before install. | | |
#84820 10/07/2006 1:28 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Sorry, no help here either, I used a switch From Chevs of the 40s and new wire with stake on terminals | | |
