7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl), 117 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#84816 09/23/2006 12:53 AM
Two posts in same night on dash board stuff..you guessed it, I am in the process of wiring up my 46 1/2 ton.
I purchased a Jim Carter's harness. Included in the harness is the wire that runs from the ignition switch to the coil. The original setup has it installed inside the armored housing. I took the ignition switch apart and the got as far as the switch mechanism. Does the mechanism pop right out or is there a trick to installing a new wire inside the armored housing? I don't want to destroy the inside of the ignition switch if I can help it...
Long question short...how do I put a new hot lead in my ignition switch without destroying it?
Thanks in advance
#84817 09/26/2006 5:08 PM
I havent been into the switch on mine (YET!!!) so I am not much help.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#84818 09/27/2006 3:31 AM
Thanks Toyvo,
I'm heading out of town on biz...when I get back, I guess I will just take the plunge and mess with it a little more...if I mess it up, I guess i buy a new one and not worry a bit... grin
#84819 10/04/2006 9:43 PM
OK, here is what holds an ignition switch on a 46 together; there are little indentations on the switch that hold the plastic inside the switch. I pushed out the indents with a screw driver and the guts of the switch came out. The original wire is held into place with solder and crimping as well as a crimp to hold the wire in place without placing any stress on the the connection. I soldered a new wire on and put it back together. Now I need to bench test it to make sure it is all working right before install.
#84820 10/07/2006 1:28 AM
Sorry, no help here either, I used a switch From Chevs of the 40s and new wire with stake on terminals
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
