Hello!
I am in the process of bolting up a 1954 chevy powerglide transmission to my 1954 6 cly and having problems with the alignment of the flywheel. Converting to a 12 volt system so I have a 160+ tooth flywheel from a later model 6.
Now I need to line up the "X" on the flywheel with the "X" on the torque converter when I bolt them correct. My problem is my flywheel does not have the "X" stamp on either side of it. I cleaned the flywheel up really well and still no luck in finding the stamp on either side. Now there is a triangle and timing marks on the flywheel facing the engine - how can I determine the correct flywheel position or will it not be a big issue?
would appreciate some advice.
Thanks!!!
[IMG]
http://i852.photobucket.com/albums/...%20Corvette/Engine%20Restoration/20b.jpg[/IMG]
