3 members (keithfielder, Stewart2, Rich'sToys), 122 guests, and 2 robots.
Topics128,103
Posts1,056,534
Members48,448
#847051 04/27/2012 1:58 PM
I have a question regarding the difference in the 1954 6 clyinder valve cover and 55-57 valve covers. The valve covers appear exactly the same except the 1954 has 4 vent slots on the top which later ones do not. Now the oil fill cap I am using on the 54 is the flat type....what is the reason for the vent holes and does it relate to the down draft tube and the oil cap used?
I have a REALLY nice valve cover from a 55 than I want to use on the 54 engine but not sure if the vents are absolutely necessary.
Thanks for the clearification
The slots are the air source for ventilation. At speeds above 30 MPH, the airflow past the end of the road draft tube creates enough vacuum to pull air out of the crankcase. The air coming into the valve cover supplies the flow that ends up coming out of the draft tube. Use a vented oil fill cap to get the same result from the non-slotted cover.
The slits in the 54/55 valve cover were to allow "breathing" when using the standard flat valve cover cap (non-breathing cap).
The are a few disadvantages in this 54/55-1st only set-up which are avoided with the later valve covers with no slits and using a breather-cap.
Tim,
What are the disadvantages besides the possibility of water leaking in the rear slits from the cowl vent tube?
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
The cowl vent tube as seen in this page from the 1954 Factory Assembly Manual does not go straight down on the cover but is set at 45 deg offset +/- 10 deg to avoid water ingress.
http://good-times.webshots.com/photo/2377893620102454676eobulj
Since there is no way to filter the air being introduced into the valve cover, dust and moisture can enter the engine and contaminate the oil. When Commiefornia decreed that all cars on the road had to be retro-fitted for PCV valves in the late 1970's, the conversion kits we sold had a fresh air tube that was attached to the "clean" side of the air filter to provide filtered air to the crankcase.
Samantha,
You and HrL described the two major disadvantages: water getting in the slits and unfiltered air getting in the slits. Also, the area around the slits sometimes get a little oily/dirty.
The major obvious disadvantage is water getting in - you have to cover the slits if/when you ever use water-spray to clean/rinse the engine.
As Brad showed, the cowl-vent drain-tube should direct water away from the slits (If installed correctly). I put a removable extension-hose on my cowl-vent drain-tube to dump the water right to the ground (if/when I get anal, the hose comes off easily for shows).
Well thanks much for the lesson. It all makes sense now. Even the valve cover on my 31 chevy has slits in it as well so now I know. I was able to take a dremmel with a circular cutting blade and carefully cut 4 slits as needed.
Thanks to all !
John Lanning
