5 members (TexasJim50, carbking, baldeagle, Hotrod Lincoln, 1 invisible), 87 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#847925 04/30/2012 11:26 PM
I was lookin for a new engine (235/261) for my 1956 chevy truck and came across a 235 from a 1954 gmc wit all new rings And bearings and runs really good as I watched the 54 in parades before. I was wandering if this motor would fit alright in my 56 or if there was any big differences as Im aware the 54 was the Earlier years of the 235 in trucks and I'm also wandering if the gmc engine would fit in place of the Chevy. And if it would fit ok is there any real differences in the motors themselves like horsepower, oils pressure etc? Any help would be greatly appreciated smile
Also wandering if I would be better off just lookin for a 1955 to 1962 engine? It's cause the motor in my 56 is pretty tired and worn so I would like to just do a complete motor swap as it tends to be easier and cheaper
Than rebuilding my ol 235
The 235 in the '54 will have a different block from the '55 and later but should bolt up fine to your '56. The fan will be further from the radiator so you might need a shroud.
Only 1955 2nd series through 1959 will have the front side mount provisions needed for your 56.
BTW GMC did not use a 235 originally.
My Blog
He lives in Canada so the GMC probably did have a 235 originally.
I forgot about the side mounts. They are not on a US '54 235.
Sorry, missed the Canada part.
My Blog
I'd look for a 56 or newer 235. It will be a higher compression and higher horsepower engine. Someone else will have to comment on the 56 and newer front/side motor mounts (on car/truck engines).
