2 members (Kilted54, UtahYork),
72
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84771 10/25/2007 11:59 PM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Hey everyone, I made progress reviving my 1953 1-ton - replaced water pump and engine running smooth now. I now return to a problem I queried about in a previous post: (http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=014247;p=1#000000
We couldn't figure it out. My clutch seems stuck in an open position, or something. I can shift through all the gears with clutch depressed or not pressed, with the engine running. And nothing happens, the truck doesn't move an inch. No weird sounds, it just shifts through all gears. It's gotta be something in the clutch, right?
My '53 has a '59-'60 235 in it. I'm wondering if the clutch or trans is not matched up right. Can I find serial numbers on the clutch and trans to identify the year and model? | | |
#84772 10/26/2007 12:34 AM | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Colorado51three- quarter, It could be something to do with the clutch, or broken transmission parts, broken "U" joint, driveshaft, axle[s], diff. side gears, more detective work required, sorry I couldn't help more. | | |
#84773 10/26/2007 12:45 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | If you pulled the little gravel shield and took a peek inside the bellhousing with a good trouble light you might find the answer to some of your questions.
Things don't usually just give up the ghost in the clutch/pressure plate area. This should be fairly easy to figure out. Start at the engine and work toward the rear. When things aren't rotating anymore, you have found the broken component.
Stuart | | |
#84774 10/26/2007 2:30 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Be careful working under it. You don't want to suddenly fix a problem and have it run over you...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
