4 members (Ole49GMC, baldeagle, Napco Man, jmoore), 136 guests, and 0 robots.
Topics128,037
Posts1,055,469
Members48,424
#84768 10/25/2007 9:25 PM
Apprentice
Apprentice
I've got a 235 with fenton intake with 2 one barrel rochesters. What should the vacuum reading be with engine at idle? thanks
#84769 10/26/2007 12:59 AM
Take a look at http://www.centuryperformance.com/vacuum.asp It explains pretty well the various conditions. If you have a hi-perf. cam be aware your vac. will be lower than stock at idle due to valve overlap.
Doug
#84770 10/27/2007 2:50 AM
My 250 with three one barrels has 19.5" @ idle. The amount of carbs should not change the vacuum. One or three, it will be the same. I would bet a stock 235 will be in the 18 to 20 range depending on the valves and ring condition. A bigger cam will lower it like Desertdog mentioned, could be as much as 2 to 3 inches lower. Timing can also raise or lower it a bit. Joe
