3 members (baldeagle, cmayna, Gray_Ghost), 61 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#846598 04/25/2012 11:43 PM
I recently bout a 1963 c60 for our company because it has a dumpbed. Well none of the lights on the back end of the truck work. Does anyone have any wiring diagrams for the 63 chevy truck?
hardy541 #846637 04/26/2012 1:32 AM
Welcome aboard.
I'm not familiar a C60, I have a C20, but wiring is pretty much the same. There are three wires to to the rear lights, turn signal right, left, and tail lights. The wires run from the firewall, a connector just above where the accelerator linkage comes through, down along the drives side of the frame to another connector about the where the spare tire is. The wire split at the the rear connector for right and left. In that the dumpbed is third party, can't say what was done, from the rear connector back. I'm also assuming that you have front turn signals so you don't need to check from turn signal to firewall.
Here's a link that should help;
http://www.64moneypit.pages.qpg.com/6066chevytrucks/id12.html
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #846975 04/27/2012 3:00 AM
Thanks for the help! I checked the connections with the test light and don't have any power though. My front turn signals work but I can't seem to find any power at the 3-piece connector. Any ideas? I was thinking just tap into the front turn signals and run a new wire to the back.
hardy541 #847018 04/27/2012 5:17 AM
Check for power on the inside of the cab, at the plug.
Check for power on the inside of the engine bay, at the plug.
Check to see if the harness runs from the firewall plug to the rear of the truck.
Check to see if the wiring or insulation has been compromised, throughout the length of the harness, to avoid any electrical mishaps.
If the wiring is there, great...if it is not, install it to the rear lights...yellow, brown, white, light green & dark green (reverse)
Here is a link from Jolly's GMC site. The wiring is the same for a Chevy.
http://www.6066gmcguy.org/Electrical-01.htm
Good luck Larry
elmeyer44 #847565 04/29/2012 3:15 PM
Don't forget proper grounding. (dirty sockets.)
gazim #848894 05/04/2012 7:35 PM
Gounding was the issue with our rear lights- a good cleaning and they were working like new- if you splice off of the front- I think you will not have brake lights... Likewise if you splice from the back to the front indicators- you will get both indicators going bright when you hit the brakes... I've seen a truck wired this way.
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
SLAWNSKI #849939 05/08/2012 11:49 PM
I forgot to say that none of the wires to the lights on the back are hooked up...they have all been cut. The place that I don't have power to is the 3-prong connector. Is it possible to re-run those wires? Run 1 wire from the brake pedal, one from the headlights and one from the signals should cover it correct?
hardy541 #849959 05/09/2012 1:43 AM
The power for right turn and left turn signals comes from the turn signal, and will only be there on brake and turn signal. The power for the tail lights comes from the light switch. IF you bypass the turn signal switch, no blinking, turn signal. I have seen the turn signals go bad because of too many amp draw or bad ground on the rear lights. The turn signal contact posts with too many amps on them will over heat and move out of position, no contact. That does not account for the tail lights which are on the light switch. I suggest you use a VOM or test light and trace back from the firewall connector.
Larry
