7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy),
67
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Have you tried the choke?
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Nice truck. The accelerator pump in the carb is probably bad. Those carbs are real simple to work on. If the pump is not working get a kit & give it a minor o-haul. If you are not comforable doing it yourself find an old time mechanic to do it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2000 Posts: 1,970 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,970 | Gorgeous truck by the way. Congrats to your father inlaw.
Professional Novice
| | | | | Joined: Nov 2008 Posts: 18 New Guy | | New Guy Joined: Nov 2008 Posts: 18 | Nice truck. The accelerator pump in the carb is probably bad. Those carbs are real simple to work on. If the pump is not working get a kit & give it a minor o-haul. If you are not comforable doing it yourself find an old time mechanic to do it. You're the second person to suggest the accelerator pump so that's probably the problem. I am very comfortable putting a kit in it, but is there an accelerator pump in a rebuild kit? aren't most of them just gaskets and a needle valve? Thank you for all the complements on the truck. It has come a long way in the past 10 years. When we started it had a tree growing through the box and today it is winning awards. My father in-law has carpal tunnel syndrome in his wrist from writing cheques for this truck but he is very proud of it also, so I guess it was worth the effort.
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | The accelerator pump MAY be an issue, it may not be. They are very easy to test: http://www.thecarburetorshop.com/Troubleshooting.htmReplacing an accelerator pump that isn't bad is not going to solve your issue. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2008 Posts: 18 New Guy | | New Guy Joined: Nov 2008 Posts: 18 | The accelerator pump was bad, the carburetor was filthy and there was a ball valve jammed so far back into the plug that it wouldn't come out and had to be replaced. The springs were also worn out. I purchased a used carburetor for $20 and used those springs and the plug for the power valve. Now you just touch the starter and it fires right up. it's amazing how good that old truck runs. Once again, thank you gentleman for all your help. Now we have to tune, tweek and adjust everything so a 78 year old man can drive this truck everyday like he did 56 years ago.
