Nice truck. The accelerator pump in the carb is probably bad. Those carbs are real simple to work on. If the pump is not working get a kit & give it a minor o-haul. If you are not comforable doing it yourself find an old time mechanic to do it.
You're the second person to suggest the accelerator pump so that's probably the problem. I am very comfortable putting a kit in it, but is there an accelerator pump in a rebuild kit? aren't most of them just gaskets and a needle valve?
Thank you for all the complements on the truck. It has come a long way in the past 10 years. When we started it had a tree growing through the box and today it is winning awards. My father in-law has carpal tunnel syndrome in his wrist from writing cheques for this truck but he is very proud of it also, so I guess it was worth the effort.
