5 members (fonz8261, frogfarmer, 78buckshot, greenie-reddy, Ricks Big Dump), 154 guests, and 3 robots.
Topics128,117
Posts1,056,642
Members48,450
I HAVE A 65 CHEVY TRUCK,LEFT SIDE FLASHES FAST,RIGHT SIDE NORMAL,ALL SAME BULBS,COULD IT BE FLASHER?ALSO IS THIS TRUCK SUPPOSED TO RETURN TO OFF AFTER SIGNAL LIGHT LEVER IS ENGUAGED,I HAVE TO RETURN IT MANUALLY,IS THAT THE WAY THEY WERE OR IS MINE BROKEN? THANKS
should reset automatically after turn, probably broken plastic piece inside Could be ground is not good on the bulbs, current determines flash rate. If it's the front hood lights scrape around the hole socket goes into, and clean off sring clips that hold it in hole on socket
If your turn signals are not turning off(cancelling) your cancelling cam in the turn signals is bad. Not hard to replace will require pulling the steering wheel off. Most of the vendors have replacements. If you want to go direct to the factory here is a link that will get you to the catalog;
http://www.shee-mar.com/PDF/2011%20catalog.pdf
After the catalog downloads (not long) go to page 32 for turn signals, page 29 has cams, good illustrations. They seem to have forgot to put the years on them, new catalog. ?? 8-[
Larry
I don't own a vehicle that isn't old enough to drink.
sounds good,,thanks for the info
