| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | I HAVE A 65 CHEVY TRUCK,LEFT SIDE FLASHES FAST,RIGHT SIDE NORMAL,ALL SAME BULBS,COULD IT BE FLASHER?ALSO IS THIS TRUCK SUPPOSED TO RETURN TO OFF AFTER SIGNAL LIGHT LEVER IS ENGUAGED,I HAVE TO RETURN IT MANUALLY,IS THAT THE WAY THEY WERE OR IS MINE BROKEN? THANKS | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | should reset automatically after turn, probably broken plastic piece inside Could be ground is not good on the bulbs, current determines flash rate. If it's the front hood lights scrape around the hole socket goes into, and clean off sring clips that hold it in hole on socket
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | If your turn signals are not turning off(cancelling) your cancelling cam in the turn signals is bad. Not hard to replace will require pulling the steering wheel off. Most of the vendors have replacements. If you want to go direct to the factory here is a link that will get you to the catalog; http://www.shee-mar.com/PDF/2011%20catalog.pdfAfter the catalog downloads (not long) go to page 32 for turn signals, page 29 has cams, good illustrations. They seem to have forgot to put the years on them, new catalog. ?? 8-[ Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | sounds good,,thanks for the info | | |
